You're most welcome. All the different arm options can make your head spin, I know. With your budget, the ISOkinetic arm paired with the Van Damme cable sure sounds as the way to go. Should also be a great match with your ZU 103. Including armboard total cost will be slightly over 600, though. Cables can always be updated in a later stage, when funds allow it.
To me it seems a very wise decision to first sort things out with the amp and pre-amp in order to set the budget for the arm. Good luck with all the listening and reviewing, and don't forget to enjoy it I might add! Keep us informed, I'm curious about which arm it will be eventually
Turntable Technics SL-1210mk2, Origin Live modified OL1 tonearm, Van Den Hul rewire, LDA/MCRU Step 2 PSU, Ianmac bearing, Isonoes, Achromat, Clearaudio Twister
Cartridge Audio Technica AT33PTG II
Tape Technics RS-AZ6
SACD Sony SCD-XB790QS
Ampification Accuphase E-205
Speakers Dali Ikon 6 Special Edition
Sub REL Strata II
Cables Van Den Hul: MCS-150M and D-502 Hybrid (Tonearm), Integration Hybrid (SACD, Tape), CS-122 Hybrid (Speakers), The Second (currently unused). Canare: 4S8 (Sub)
