Results 11 to 20 of 34
Thread: DIY Power blocks (4 sockets)
    I'm Hugo.
    I didn't say I know more than you about it, but every mains block/mains smoother equipped thing I've heard has degraded the sound.
    This has also been my experience.
    Hi Rikardo
    I like the Olson cases
    I would wire each socket in parallel back to a fixed point as per your star earth, not in series
    Alan
    Quote Originally Posted by 337alant View Post
    Hi Rikardo
    Alan
    With the cable lengths involved, it won't make blind bit of difference if the sockets are wired star fashion or are 'daisy chained'.
    I'm Richard.
    Hi Rikardo
    Alan
    that is my plan. use same length of all wires into push in connection and than out.
    Thx for suggestions.
    These are going to be 2m long each
    I'm Richard.
    so some last missing bits arrived today
    So lets Rock and Roll
    I'm Richard.
    so the first one is done
    Also 1st post of this thread has been updated and all is documented there so feel free to check and ask.
    BTW, admins or mods, how to do spoilers here? the normal bb code seems to not work?? any help on this please?
    I'm Deleted.
    Looks really well done .
    Account Deleted
    I'm Richard.
    I have decided to do Left and Right version design so it would be easier to keep it closer to the wall with plug cables facing away the wall(depends on what side of wall your socket is)
    I'm Deleted.
    Don't you already know which side your wall socket is on?
    Account Deleted
    I'm Richard.
    yes I do I have one running from left another from right
    I have 10 devices plugged in behind the unit
