Depends on the cart, if it comes with nuts and bolts use them. If that is the case the nuts will fit into the slots in the body of the cart. If it doesn't have any - used ones sometimes come with no hardware - then I guess it depends if you have the right bits and bobs kicking around that fit.
I recently had to raid my own stash of cart bits to fit a brand new cart for a friend, no nuts in the packaging and none I had would fit, so I ended up nuts at the top - a right royal pain.
The best type to work with/set up is carts with threaded inserts, so the bolt screws down into that.
Regards Neil
Agreed, as long as you use the correct length fastener, or you will damage the cartridge.
Kevin
I'm Deleted.
On mine the nuts are on top because that's how the cart was designed to be fitted - there isn't a right or wrong to it though. Personally I'm a fan of stainless steel fittings and wouldn't use aluminium or nylon bolts. I wouldn't use fibre or nylon washers etc either.
Account Deleted
Hi James.
Just to let you know, the interconnect will be with you tomorrow.
Tannoyista.com - Audio Equipment Reviews
