How do you bolt your cartridge onto your headshell.
Nuts on top of headshell or nuts at bottom of cartridge !?
Nuts down below where they belong
I was expecting that one.
Nuts below. My headshell has circular pockets for the screws/bolts.
Hexagonal nuts don't fit. It also looks neater.
Kevin
Is there a right or wrong or rule of thumb?
Or does it all depend on cartridge and headshell type.
Does it matter?
I don't think it makes a blind bit of difference as long as it is mounted correctly.
Kevin
I'm Sam.
Whatever fits! Some carts won't allow nuts at the bottom because there's not enough of a recess in the cart body.
