Page 4 of 4 FirstFirst ... 234
Results 31 to 38 of 38
Thread: Digital stylus gauge
  1. #31
    I'm Ben.
    Why worry? The tracking force needs of each cartridge will vary, even of the same model! Then the ambient temperature variations have an effect, as does the age of the cartridge. Nothing is exact. If the cartridge is tracking and sounding OK, I'd say there's little to be concerned with.
    I hadn't considered those variables Geoff, makes perfect sense though. Good to know the gauge is accurate as a starting point and then use my ears from there. The trouble is, we could apply the same variables to our ears as well! Add a few beers to the mix and I may as well be using the kitchen scales!
    Sources: Linn LP12>RegaRB251 arm>AT95e cart>Mose Hercules PSU / Quad 66 CDP / SPS Battery DAC3 / Airport Express
    Pre's: Retro Thermionic Mimic SE Battery Phono / Tisbury Mini Passive
    Amps: Amptastic mini T / Arcam Delta 290P
    Speakers: DCM Time Window 1a / DCM Timeframe TF500
    Power: Retro Thermionic DC Duffer
    Cables: Mixed bag of el cheapo's.
  2. #32
    I'm Charlie.
    You might like to read this article on tracking force, the type of tonearm and the influence of measuring the VTF at a different height to the record.
    http://www.tnt-audio.com/sorgenti/in_balance_e.html
  3. #33
    I'm scott.
    as used a jesus to fit his Spu
  4. #34
    Quote Originally Posted by daytona600 View Post
    Got one of those too... its pretty good and I used it faithfully till I got the digital one a couple of years ago; maybe less.
    I'm martin.
    Default Digital Stylus gauge
    I think if you go on the www.audioorigami.co.uk web page he has a digital stylus gauge for £20.00 + £3.00 p & p.
    Martin
  6. #36
    Quote Originally Posted by topoxforddoc View Post
    The overestimate factor is simply 1/cos(h/L), where h is the height error (or the difference between the height of the scale's measuring platform and the thickness of the LP) and L is the effective arm length.
    So for a 9" arm and a set of jeweller's scales with a thickness of say 0.25", the error is 1.000386. Thus a measured 2g VTF will actually be 2.001g. This is likely to be less than the accuracy of the scales themselves (at best to within +/- 0.01g), so is not worth worrying about.
    And if you are going to worry about it, what happens if you change the VTA, or for that matter, play heavy (and thus thicker) LPs?
    I'm Simon.
    I've just got one of these but I can't get it to work. I cleaned the sticky stuff off the batteries but nada. Fair play to the seller though - gave me a refund with no questions asked.
    Quote Originally Posted by Aligauld View Post
    Hi There
    I use one similar to this and it's given me no problems.
    http://www.ebay.co.uk/itm/Digital-Ca...sAAOSwgyxWWd7j
    This was the first link showing on a search so there might be cheaper versions.
    When it sits on the platter its just the right height.
    Cheers,
    Alistair
    Simon.
  8. #38
    yep I have the same, reliable.
