Technics SL1210 MK5g - (Modified)
Sansui AU 919 Integrated
Pioneer PD91 Reference CDP
Mission 752 Freedom
Mission 752 Freedom
Hows that Robert? Copy the image URL then paste into the 'Insert image' function above.
Bless ya Alan, very much appreciated
Looking good, Rob, and by all accounts sounding it, too!
Just one thing... It's probably just the angle of the picture (and it's often difficult to tell with S-shaped arms), but is your tonearm a little 'tail down':
Have you checked it with a bubble level (placed on the headshell)?
Hi Marco, Yep, slightly tail down. Obviously initial set up is towards as perfectly horizontal as pos. However, you'll find that the sweet spot with the QB / Shibata stylus profile is a slightly negative rake. Someone else here posted that they too found this to be the case which wasn't a surprise as I found this with the 2M Black as well. It's why I wont be without on the fly vta as after everything else has been covered there's nothing better than being able to dial the all important right spot / sweet pot whilst listening
Btw - Thanks for the heads up regarding the Missing Link unswitched socket and plugs which are excellent
No worries, matey. If it sounds best that way, then best it is
Glad that the Missing Link sockets and plugs worked out well... Enjoy yer choons!
MMMMMmmm... Nice!
A PD-91 too, a smashing player. I've had one and would have another too!
Tannoyista.com
Not sure whether I'm drooling over the Sansui or the Pioneer. Or both.
Almost certainly both.
Did you have a listen to that Sansui before you bought it, Robbie? If I wasn't sorted for amplification I be tempted to have a go at one, or an Akai or JVC from similar era.
Hi Martin, I'd never heard the AU 919 before but had a hunch it was the one for me. I was determined to nail something a bit special and after doing loads of my own research I sensed this was the one to seek out. Hand on heart it is absolutely everything I hoped it would be. I have never heard an amp sound so good with tone defeated, it's amazing. It is in my opinion a genuine Reference amp, the search is over
So a blind punt then it's always great when that works out. The Yanks go nuts for them. I've noticed.
BTW If you ever want to move that Pioneer on you know where I am
