Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: CD playback fault
    I'm Barry.
    Default CD playback fault
    My Exposure 2010s has developed a bug , it plays a speeded up clip before the track starts , the track plays from the beginning ok and continues ok as does the CD right through.
    If you select a track it does the same thing quick bit then starts properly. Also when paused it will play the note or word endlessly.
    I'm Oliver.
    My player does the same thing, but only when used via an external Dac.
    Are you using yours as a transport only ?
    I'm Barry.
    Quote Originally Posted by OD1 View Post
    Thanks Oliver thats it , I've just moved mine to a second system and need to use a DAC because the amp only has two inputs.
    btw what brand is your CD player ?
    Sounds like the mute is coming off too quickly
    Maybe defective or dirty muting relay contacts or faulty components in the analog circuitry
    I'm Barry.
    Grant I've edited my post , its the same as Oliver's only happens when used with DAC.
    Just noticed from another thread Oliver has the same CDP.
    Strike them then.. Must be in the digital domain... Are you both using optical ot coax?
    I'm Barry.
    Optical but I will try coaxial to see.
    I'm Oliver.
    I am using Optical, I could not get the coax to work.
    I think the Exposure has a muting circuit in its internal DAC, my Caiman does not AFAIAA.
    I have tried 2 blu ray players with the Caiman, and no problems, so I assume that the problem is not having a muting circuit in the DAC
    Oliver
    I'm Barry.
    Just tried coax and nope nothing same as Oliver's , so is this a fault ?
    Anyway at least its ok as a one box CDP.
    I remember folk diy-ing cd player o/p mute transistors by removing them to improve the sound; the digital circuit should have a mute , either transistor or on the chip. as its on 2 of same machines, then it may be that the company did away with this mute; find it unlikely that 2 machines develop the same fault or have both been modded.....but you never know
