Geoffrey – what is your response to the statement ‘How many channels do you think it takes to make a music listener happy; One. Mono's fine. I've never heard anybody bitch about Louis Armstrong, saying, "I would enjoy it if it were only stereo"
Now this question is interesting from several perspectives and I’m going to come at this sideways, so bare with me for a minute. In the first instance, the greatest portion of what you hear ( in the context of both live music and recorded music ) is reflected off walls, ceilings and floors, so unless you listen to your hi-fi in an anechoic chamber, the dispersion characteristics of your system contribute significantly to your enjoyment of the music.
But here’s the contradiction – dispersed sound is a mixture of phase shift, time delay and echo ( try swapping the leads of one speaker ) Referring back to question 1 of this interview, ‘can a sound be wrong but good’, yes – with the right music, an artificially diffuse sound can be ‘wrong’ but give the impression of an enormous sound-stage.
For this reason, and returning to answer the question - I don’t mind the use of rear speakers in conjunction with Ambisonic electronics. ( quasi 4 channel - IMF, circa 1980’s ) However, when it comes to Quadraphonics, I just don’t see that it contributes anything other than sending a strong message to one’s wife/girlfriend that invites divorce. For me ..... it’s a gimmick and one that demands the listener sits in a swivel chair, in the middle of a room with no furniture between you and the four speakers spread 90 degrees apart - 4 channels is not for me.
Okay, thanks. So how do you apply this to your design engineering?
When designing speakers, I .....
Continues @ http://www.hifianswers.com/2016/02/h...ck-part-three/
