Results 1 to 3 of 3
Thread: wharfedale 505-2 question
    I'm mike.
    Default wharfedale 505-2 question
    anyone have any hints or tips for getting the woofer out of the cabinet..
    .thanks.
    It's a 'twist' fit if I recall. I believe Wharfedale used to insert them with a large key that went around the outer frame. I suspect you need to rotate it carefully anticlockwise somehow.
    I'm mike.
    thanks,, tried using a makeshift brace but they wont budge, anti clock wise nor clock wise...ill keep tryin....
    thanks again for input
