Looks like it to me too. Looks glued ?
if it is then that could compromise the earthing
I can't find the other end of it. Doesn't seem to go anywhere !
It's unlikely that the arm tube will earth directly via the rear clamp. It has a thickish enamel (powder coat?) finish that will no doubt act as an insulator.
Yep. Tried that and broke two wires.
Just found this
From what I can tell with mine, this is correct. That yellow wire in the arm isn't connected to anything that I can see. There is a separate yellow wire entwined with the black - wire from the cart to 4pin sip. Where it goes after that I don't know. I know the wiring diagram says to connect the external cable earth to the fixing plug so where would the internal yellow cable run to ?? I'm absolutely lost.
I'm going to have to take a trip to Firebottle towers I think.
Off to see Alan (firebottle) with it on Wednesday, hes a genius so im pretty sure he'll unmask the hidden nasty
