I might ask Alan to do it lol
I have asked Alan. I've just soldered a spare tag on the arm I checked. It buzzes now lol
I am not 100%. I'll have to have a look !!
No connection to the arm earth other than the one that's supposed to be there . When I connected right + & - together and left + & - together it was silent. Even with the motor running. Shouldn't that indicate proper earthing.
Ok, so I've just disconnected the cartridge and connect L+&- together and R +&- together and it's silent again. Reconnect the cartridge and it's buzzing again. Could it be the cartridge ??
Have you got a meter? It might be handy to check continuities and exactly what is earthed to what or through what. If needed, a cheap one is about a fiver. Try Maplins if there's a branch near you.
It's unlikely to be the cartridge, unless the body is touching something it shouldn't. The metal cartridge body should be earthed via a small tag that is over one of the rear pins if I recall.
There is one there. I've swapped the negatives over so the arms earth is connected to the tag but still buzzing.
I do have a meter but no idea how to use it to check for earth faults !
Ok I'm on it.
I took the sticker off expecting to find a brass rod ? Just a wire. Is this right ?
