ive just bought a few blocks from my local recycle shop on a whim, is is worth bothering with and if yes wheres the best place to use it?
im thinking between 2 hifi rack shelves underneath the turntable??
My System
John Wood KT88 Amp.
Paradise Phono Stage
Sony TTS-8000 Turntable.
PMAT-1010 MK6 Tonearm.
Ortofon Cadenza Bronze
Sony X555ES Cd Player
Yamaha NS1000m Speakers
Be careful where you put it. Plasticine contains oils that can leech into porous materials.
wrap it in shrink wrap loosely several times and it will be ok.
Ta.it will probably end up in the bin Geoff, the blue tak seems to work under the turntable well so thought I'd try it
My System
John Wood KT88 Amp.
I once filled the underside of my 124 with plasticine thinking it would add mass, it did and the bass was more concentrated, but after a while I realised the life had gone, the dance was subdued, so I took it out.
My deck is now in a solid plinth and I use 1" thick Sorbothane blocks for isolation.
my 2 penneth.
cheers Al
My system,
Cartridges Lyra Delos, Audio Technica AT33EVmc, AT 24 mm
Turntable Thorens TD 124 Mk2, in a Jim Campbel plinth,Audio Technica 1503 Mk3 arm
CD player Technics SL-PG490
Cassette deck Yamaha KX 530
Moving Coil Amp Albarry MCA 11
Pre-amplifier Albarry AP 11 (battery powered)
Power amps Albarry M1108 Mono-blocs
Speakers Allison 3 Corner units, Allison 6 stand mounted cubes
Interconnects AVT Matrix 6 and OFC short ones
Mains distribution Music Works Recoil 6 gang and mains leads
Tables MusicWorks ReVo acrylic stand, Quadraspire Acrylic shelves (cryo'd legs) acrylic Response Mini under mains block.
Speaker cable Chord Rumour (Cryo'd)
RCM Okki Nokki
https://www.facebook.com/groups/1586...homepage_panel
When fresh and pliable it could well be useful for isolation. But unless periodically 'kneaded', it will become hard and stiff, negating any useful properties it has when fresh. The same goes for BluTack. I would suggest you would be better off and experiment with Sorbothane.
Newplast modelling clay never dries out or becomes stiff...
Lepage's 'Fun tack' also known as Blu tack.
Is a rubbery plasticine like adhesive that Never dries out / becomes hard, Or leaves residue/stains. Instantly removable too :-)
Great for Isolating/fixing things like Speakers onto Wooden floors (beats the hell out of Spikes) Or? onto shelves, table tops.
