Results 1 to 9 of 9
Thread: Amp Question: audio analogue puccini se
    I'm Brian.
    Default Amp Question: audio analogue puccini se
    Hi,
    I've been offered a audio analogue puccini SE.
    I've not heard it wired up, but told it's in perfect working order.
    Are they any good, and any idea on that price I should be looking at paying for it?
    Cheers
    B
    Used to own one in my second system. Lovely amp, well built and typical Italian style. If the price is right for you, then you could do much worse.... I would guess under 200 these days. Think mine was about 250 but that was a few years ago.(presie for stopping smoking)
    Typical Italian sound - warm and mellow. Nice amp at the right price.
    I'm Attila.
    a batch from the 2nd series SEs was, at least, mis-designed having the rectifier diodes running at the edge of their specification in the PSU causing, mainly when driven hard(ish, I would say) the amp to fail, ocassionally even burn. do check (via the vents) if there's a dedicated heat sink in the amp or the O/P trannies are bolted right down to the chassis - the latter's the earlier, original SE design, the one you may be happy with without the above risk. otherwise, as the others say, it has a warm-ish, to me a bit lush-y, sound - to decide if you like it or not you should hear it for yourself
    Attila
    save the trees - eat beavers
    Much loved by Hi-fi World magazine back in the 'Nineties.
    I'm John.
    Which speakers would you be partnering it with?
    I'm Nick.
    I have one of these and would agree with most other comments it would be on the warmer, to me more musical, spectrum of sound. I really like it, especially as has the option of either mm or mc phono input (adjusted by moving a couple of switches within the amp). No headphone socket, good speaker connections, bi-wireable if that is your thing. I have partnered with Audio Analogue's Paganini CD player (which in my view is superb) and Monitor Audio RX1's which works quite well to my ears.
    I'm Neil.
    Quote Originally Posted by trane View Post
    I recall that, it affected the power amplifiers too as I recall.
    Other than that nice amp if at the right price which to my mind would be sub £200 so £170ish.
    Regards Neil
    I enjoyed mine immensely and not sure why i sold it tbh...it was very nice with opera and country n western. ..... Or so i was ..er told
