I prefer 'Z' plugs. As used by Nordost on their speaker cables.
The slit tube construction is springy and gives a good contact area and snug fit without being too tight.
I'm Gone.
OK First off I agree with Grant this stuff is amazing, Silversound used it in their speaker cable and with the correct construction, it is, in my opinion, about the best non pure siver cable around. As for constuction, each cable should have 4 strands two + and two -, then twist them together in a star quad arrangement with 2 1/2 twists per metre. As per Geoff's post, I prefer the z plugs and got some good gold plated copper from the Compass Audio guy via FleaBay. Silversounds used to wrap the cable with PTFE tape, I use plastic braiding and heat shink.
Ah ok. I might give that a go
