Here's a query aimed primarily at Paul.
Given a well used set of speakers/drive units, with the suspension and spider components well past any 'new' stiffness, is there likely to be less distortion from said units than when they were new?
I'm Shaun.
Trying to keep to subject here, I have often wondered about how loudspeakers change their sound over time. My current KEF Q500's were brand new in 2013 and took about nine months to sound totally free and relaxed. I wonder how they may change over the next ten years or so.
Hi Alan
it's not possible to offer general advice on distortion as there are so many variables involved, not least of which is the drive unit spec and cab/crossover design in the first place. However, as drive units age, and depending on the material used for the magnets, several issues to crop up to varying degrees.
Firstly, as suspension, and in some cases, surrounds become more compliant, the T-S parameters for the speakers will in fact change, so tuning points or the speaker Q (for sealed boxes) may well alter. This may not necessarily result in increased distortion on its own, but in some cases, power response or efficiency can be reduced from what is optimum. Magnets which use ALNiCO in particular can have changes to BL force factor due to weakening of magnetic strength which can occur as a result of over-driving (ie too much power driving them), knocks or lots of temperature variations and this can in some cases result in increased distortion but magnets can be sent off for re-energising to bring up to as good as new performance. The other issue is that variations can occur between drive units throwing speaker matching out.
Where Tannoys are concerned, I usually advise that for HPDs in particular, they are reconed rather than refoamed as this ensures that they are restored to a matched pair, and that suspension and Fs are restored to factory spec, or close enough to it. Depends how fussy people want to be and some aren't too worried as long as things sound ok, so little point in them pursuing real or perceived in those cases.
With some speakers having a high value for Qms (mechanical Q), this usually indicates the amount of control, openess and dymanics a drive unit may exhibit, and is purely a function of things like mechanical suspension control and control offered by the surrounds. It is a measure or an indicator anyway of how much energy might be stored. Drivers with high values for Qms tend to have fewer losses. As suspension wears so losses increase, and performance and efficiency can decrease. However, speaker drive units with high BL values, tend to have powerful motors which can control their cones better, so slight loss of suspension efficiency may impact less in those cases....or so you might think. I have measured 30 year old drive units with very high BL values which have still exhibited a loss or drop in Fs of 10 Hz or more due to the effects of suspension softening altering free air resonance but I suspect that some magnet strength loss may have also been a factor. You can also have issue with over driving of increased hysteresis depending on magnet material, strength and power applied.
It really does depend entirely on the driver design, cabinet design, loading, and variation from factory spec. In general though, speakers do start to drift from optimal design values from around a few hundred hours on new although the rate of drift is usually very low/slow and takles may years.
If they sound ok, then chances are they are ok, but for any loudspeaker used and abused over several decades, drive unit suspension will have softened up and depending on the design, crossovers may also require attention. The latter can be very economical to address and my own findings are that older crossovers are the main culprits for increased distortion, which is easily heard and easily measured (I have the test gear here to test drive units).
By using speakers with crossovers which have either dried up electrolytics in them, or loose hand wound inductors, distortion can be appreciable but easily remedied.
Small addendum :-)
Ferrite Magnets Lose Flux over time.. Starting to be measurable by their 5th Birthday and absolutely by their 10th.
Simple nature of the material.
Is this a problem?
Dunno, but it certainly was/is in motors requiring precision where deviations are quickly recognised.
Unfortunately that information is inaccurate /reversed.
Alnico has a projected/estimated Flux stability/Half life of 2 millenia !
Longer than we needs concern ourselves with.
Albeit a small setting down of alnico's magnetic domains occurs in the first day or two following initial Magnetisation.
Also has a Currie point ~ 850 C In case house fires are a concern :-)
Stable flux in Spades. Some myths claim that alnico needs 'a remag' periodically.
Ain't so in real life, despite babbles to the contrary.
But stories persist, misinformation is ubiquitous in our culture.. no news there
Ferrite flux losses are measurable..replicably so.. by it's 10 th Bday. Again; no news there either.
Ferrite Does generate a shaper edged Bass /impact sound though.
Alnico softens a bit on those transients as the domains deform under mag loads.. and quickly reform.
All this is researchable.. but best to limit such efforts to Magnetic materials suppliers, or ideally Magnetic materials research areas..
Not Audio sources
That's not exactly what it says here:
http://www.rare-earth-magnets.com/co...n-Handbook.pdf
Alnico's can and do go down, and can be rejuvenated. Never had any others do this in same way. Nicest sounding speakers Ive heard if made well.
My Telefunken ones are suublime
Presumably all this apply to cartridges as well?
Time flies like an arrow.
Fruit flies like a banana.
