Page 3 of 10 FirstFirst 12345 ... LastLast
Results 21 to 30 of 91
Thread: Bo!ng Isolation feet
  1. #21
    Bigman80 Guest
    wondering if these feet are suitable for a toshiba sr370 ?
  2. #22
    dont see why not... I was using Mag lev's under mine.. they were excellent.
    You want to find out the load bearing capacity of the feet. The Toshiba is way heavier than most TTs of that size.
  4. #24
    I'm Kevin.
    According to the blurb:
    4-15kg (3-Springs)
    16-25kg (6 Springs)
    26-35kg (9 Springs)
    Kevin
  5. #25
    Yeah I read that somewhere... mine do up to 24kg. Would think the 35 kg should be strong enough .. cant see it being more than that... price went up with springs I think. Often find the ones on a good jap deck are as good as you need. The micro absorbers ? on my new deck are very good.
    Bigman80 Guest
    Mag Lev's ?
    Ok now im intrigued.....dont have the original feet on the TT due to postman destruction syndrome.
    This may be the next upgrade !!
  7. #27
    Tosh is only 15kg according to specs so should be no problems
    Specifications
    Drive system: direct drive
    Drive motor: dc servo motor, 8-poles 24 slots
    Speeds: 33 and 45rpm
    Speed regulation range: 2%
    Platter: 1.5kg aluminium diecast with stroboscope
    Tonearm: static balance type s-shaped pipe arm
    Effective length: 237mm
    Overhang: 15mm
    Cartridge range: 4 to 20g
    Signal to noise ratio: 60dB
    Wow and flutter: 0.04% wrms
    Dimensions: 471 x 373 x 180mm
    Weight: 15kg
    Solidair Audio in Cornwall make the Mag Lev's... He is a member here, although not seen him post of late.
    Mag Lev's ?
    Bear in mind that these feet offer a degree of isolation, but no damping. With the 15kg mass of of the TT it's not likely to be problematic. I like big sorbothane feet under my gear, as that damps and isolates. Although I've not needed them on the SR-370. Got them under the Cd, DAC and pre-amp though.
  10. #30
    Bigman80 Guest
    Thanks Grant. I'll keep a look out then
    Big soborthane feet would be nice too.
    hhmmm what to do ????
