Any views / experience of these, anyone?
Looks interesting to a total technical numpty like me.
http://www.ebay.co.uk/itm/Quad-405-C...3D291621095388
http://www.reelaudio.co.uk/poweramplifiers.shtml
I'm gone.
Trouble with these kits is that the power supplies are always pretty light weight, with poorly designed and mediocre parts.
You also lose the classic vintage design look.
I'm gone.
Yes
I personally don't like the idea of crimped connectors on the speaker outputs.
Kevin
LJM makes some very nice boards with his own designs (google ljm) which are probably better than the 405 clones sonically. i have a pair of L15D boards with a good psu which i find as good if not better than my modded 306. I guess it would be worth a try if the price is ok ?
early version of an L15D
https://www.dropbox.com/s/lis8lm4x3g...0039.jpg?raw=1
A fully modified NET audio 405-2 is a very nice thing to own and considerably better than a stock 405. I'd go down the route of sourcing and upgrading a 405-2 via dada electronics or net audio, these guys know these amps inside out. I went down the NET audio route because a found a unit in the UK and didn't fancy the hassle of sending a sourced amp to Europe.
I'm Bob.
