Closed Thread
Page 1 of 6 123 ... LastLast
Results 1 to 10 of 52
Thread: resign
    I'm alf.
    Default resign
    is it possible to unregister from the AOS ??, or does one have to be 'booted off' ??
    'The Magical Mystery Tour Is Coming To Take You Away'
    Nope.. Like the govt...once your registered your registered i think. If you dont post anymore will it matter?
    I'm Andy.
    Just slag a Techie off and you should be good to go.
    Me so horny- Impulse H6 Horny
    I'm alf.
    Technics 1210s are not as good as NAD 5120 with the flat tonearm , is that enough to get me 'blackballed' ??
    You can get banned but your registration will still be there
    Quote Originally Posted by talisman2 View Post
    Do you want to go Alf? We'd like you to stay.
    Your first 'welcome' post and all those subsequent just drift backwards into AOS history anyway, so there's no formal 'resignation' procedure.
    What's the problem, Alf? I'm the sort who likes tackling problems head on, and trying to fix them, than running away from them...
    This is kind of like Hotel California in here. You can check out any time you like, but you can never leave.
    I like that!
    I once quoted that after I decided to rethink my membership of AoS.
    That and the Dave Gilmour line:
    "There's no way out of here, Once you're in, you're in for good"
    But seriously Alf, why are you thinking of leaving?
Closed Thread
