Yes big leather sandbags if you can find someone to make u some up. Im still looking for a nice but cheapish option re that. Those tobacco style pouches are ideal
What are those sinister looking things - are they the leather sandbags Struth mentions in the next post? And does sand have acoustic properties that my 5kg weights don't? After Dave's point that Spendor SP!s need to flex a little as part of the design I've put the weights on the bottom of the stands. This seems to have the same affect, and is less intrusive.
Linn Axis tt/Akito arm/Nagaoka MP200 or ATVM95/ML carts/Trichord Dino mk3 phono stage/dedicated PSU
Marantz CD6006/Cambridge 650T DAB
Tisbury Mini Passive II pre/Roksan K3 Dac/Roksan K2 integrated used as power amp
Atlas Element Integra Superior inter-connects
Spendor SP1s(1988)/Van-Damme UP-LCOFC HiFi 4mm cable
If the o.p. is prepared to cut into the floor I suggest getting the wobbly bit sorted instead.
I wonder if a Seagram's Crown Royal bag filled with lead shot would do the same thing?
They're Entreq Vibb Eaters. http://www.entreq.com/products/accessories-17667732
Looks like a morbidly obese rat wearing a red bolo tie. I think the novelty of having those things staring at me every time I try to listen to music would wear thin pretty quickly. Like before the first album side is done.
I might be incorrect, however I think that the Entreq Rat's do in fact contain small metal shot.
Used to have tons of these products lying around too sand, grit. metal grit shot and full steel shot. couldnt give the stuff away... now I see how I could ave made my fortune....so sad
Buy good hifi/enjoymusic/dontstress
All of the best to all re-buying for too much inferior replications of best recorded music etc.
