Valve based preamplifier using innovative 'super linear' circuit design, distributed regulation and passive RIAA equalisation.
4 line level inputs or 3 line level plus MM/MC phono input. Remote control of volume and mute.
Line level inputs: Gain 8dB, input impedance 100 Kohm.
Phono input: MM gain 40dB, input impedance 47 Kohm, MC gain 76dB, input impedance 100 ohms.
Output impedance: 20 ohms.
Line only KIN £1250, line/phono version £1750.
Some testimonials of the KIN:
'The utter transparency and ability to resolve absolute detail was unbelievable. Instruments had a texture unlike anything I have heard and vocals were utterly sublime. The realism and direct contact to the recording made the hairs stand up on the back of your neck! The KIN simply peeled back the layers between you and the recording and left you with the musicians and all the ambience and realism of a live recording in a 3D sound stage that was utterly convincing.
This amp is truly fabulous.'
'And if you are in the market for a £1750 remote control pre-amp with a seriously wonderful phonostage onboard, then you would be doing yourself a massive dis-favour if you ignore the KIN pre-amp.
Really fabulous kit.'
'Had the wonderful privilege of listening to this amp today. I do like the build quality. Feels very solid and nice quality. Volume knob is very smooth. The remote is excellent compared to the rather poor offerings I have had before from amps costing many times as much as this one.'
'BIG sound and yet very detailed. No fatigue even when pushed hard , even on some recordings I have found a tad harsh in some systems sometimes.'
