My oldest son succeeded it doing just that. Not a pretty sight, joking aside.
So the thread has no direct relevance to the Edingdale speakers it's titled after
It might as well be titled "arse biscuits"!
Chris
Common sense isn't anymore!
"Arse Biscuits" a phrase I use, but have no idea where it came from or whether I made it up. Any clues?
https://youtu.be/ZCBe7-6rw4M
Chris
AC POWER
AMPS
SPEAKERS
Wharfedale Evo 4.4
DAC
TURNTABLE
PHONOSTAGE
DIGITAL
MUSIC PLAYBACK
Ipad Roon Remote.
SPEAKER CABLES
INTERCONNECTS
Relief about the Eddies not being at fault, nearly spat out my soup wondering about mine...
'Twas said speaker that was not putting out sound so I thus used the name of the said speaker to start the thread then it developed into finding out it was the interconnect causing it
I'm Colin.
Steven,
For the record there is only one d in Edingdale and glad the issue you had was nothing to do with the speakers which I sell and make.
I do wish you would change the title of this thread as the fault you were experiencing has nothing to do with the speakers and casts some doubt about the design. It gives out the wrong vibes.
In all the Edingdale speakers I have sold I have only had one issue with drivers and that was down to the owners grandchild poking a knitting needle in one the drivers punching a hole. That was solved with a replacement driver.
Marco/Moderators
can you please arrange for the title of this thread to changed to a more suitable title reflecting the fault being a interconnect cable and nothing at all to do with a fault of the Edingdale speakers.
Colin
