Panic sound only coming out of the left channel all connections seem tight its when I have it switched to phono also happens when the CD player is on
Heard a pop when i moved the Firebottle every thing was powered up when I did this I only moved the Firebottle 1cm to the right
Is it working ok on anything?
Grant no cd or phono
Now the volumes only low in the left speaker
Should I try swapping speakers to see if it still happens with the right channel
could do.. take it thats all the sources you have. swap them at the amp (what amp is it)
Try another amp?
Hunter S Thompson
if its still same speaker then check any biamps wires and the cable. if not speaker its likely to be the amp, probably an op section
Grant I could swap the monoblocks over and see if there is sound coming out the left channel still or if it moves to the right channel I don't know if the eddies have protection fuses in for the crossovers it could be that if they have that fuse may have blown thing is what could have blown it I haven't got another amp to try at the moment
