I'm considering having another go at box-count-reduction; last time I tried this I ended up with more than I started with!
However...I've also been mulling over the possible sonic benefits, if there really are any, of the separate box route vs the integrated. The fact that the integrated has its psu and other 'heavy duty' gubbins in the same box as the 'light duty' stuff - does this outweigh the integrated not needing extra bits of cable and sound-degrading connections?
I appreciate the separate box phono stage really does need to be kept away from the power amp's toroid(s) but today I've put the P90sa on top of the A60, used really short i/c, and not noticed any degradation from having the pre sat directly on top. It may actually sound a tiniest smidge better through using only 30cm of interconnect (SuperSoundpipe in this instance). It made me think 'why don't I just be done with it and get a big integrated'.
Thanks for any views/ideas.
