Over time, I'll add some more details and images to this thread, but I thought I'd start off with a few images of my home theater system. It is a DIY system that has taken several years to build...
The overall theater room is 14 feet wide and about 24 feet long.
Front view of the theater:
Rear view of the theater:
The front speakers are open baffle and stand about 52" high and weigh over 120lbs each. The surround speakers are acoustic suspension and use the same mid-woofer as the mains. Each front speaker is driven by its own 125w Class-A amp (a clone of the X-Aleph amp from Pass Labs). I had Class-D amps driving the surround speakers, but had to replace them with other amps as my local power utility began using two-way automated communication system (TWACS) that bled noise into the amps and out through the speakers that just drove me nuts!
I'll provide some additional details and some construction pics of the amps and speakers in a little while.
Eric
