Dear all,
can anyone recommend a good cleaning service in London, or maybe you are a member with a machine and you want to help me clean a couple of possibly rather valuable LPs that I don't want to flush away in my Knosti? Happy to bung you some vinyl in exchange if I have anything going that you are interested in... I am in N1 if that makes any difference.
Thanks,
R
P.S. If you can't help with that, but have any tips on how better to use a Knosti that would also be gratefully received. I'm currently using home made fluid with 200ml Isopropanol 800ml distilled water + half a tsp Kodak Photo flo (thanks to my friendly neighbourhood photo lab for that!). I am doing double bath ending with distilled water + drop of Kodaflo, and the results are pretty good, but I am noticing odd lines which look like where the brushes pause their rotation on one of my much older LPs. Also after extended cleaning a well played 1965 Mono LP is still clogging up my stylus with gunk on every pass... Any advice welcomed (though "buy an Okki Nokki" is not that helpful, though maybe if I make a mint off these few LPs that may be a next move....
