Yeah. Bet neither will cough up much to the developement costs.... Not much lower than big business
Inevitable I suppose. The broadband is dropping out constantly and the landline is extremely noisy again. It only took a bit of rain to set it all off once more. BT's Openreach vetted everything here last week and claimed to have cured a fault on their outside equipment. Not properly evidently. Bugger!!
I'm Alex.
Oh dear, sorry to hear that. If the audio is noisy on the phone, perhaps provide BT with a recording.
Spendorman
Not good Geoff... I had that problem for over 10 years b4 they replaced the box on street and fitted new one in a waterproofed concrete casing. Was same problem when it rained a lot(and it does that here all the time lol)
There have been problems here for many years. They've sorted it in the past, but it comes back. Seems relatively OK right now. Couldn't use the internet at all earlier. I phoned the SP helpline and the girl at the other end was amazed how much noise was on the line.
I'm Alex.
Sod's Law, probably will be OK then.
It's said that the only time sod's does not apply, is when one tries to prove it. Normally, if one drops buttered bread on the floor, it will land butter side down. However, if buttered bread is prepared with the purpose of testing the law, it will land butter side up.
Spendorman
Internet & phone now properly sorted apparently. A further investigation by Openreach found a cable break at a junction box a couple of hundred yards from the house. This had been causing the intermittent signal and noise. The problem must have existed for years as this line has played up for a long time. Seems fine now even after a fair bit of rain.
Goodvto hear..hope its fixed fixed this time
