Sounds like a result then. Cheaper than a new pc
I'm Alex.
I just need a snappier brain to keep up with the computer.
Certainly I can recommend these Hybrid drives an economical way of speeding up a computer. Suspect that I will be fitting these for some friend's machines.
Spendorman
Attempting Time Travel The vista pc I bought and put win 7 on has been playing up of late;think its the windows 7 updates that are screwing with it, so trying to put win 10 on it. It passed the test for compatibility and is still in update stage so it could be some time. Hoping it becomes more usable. I did take an image of it just in case.
I really don't like W10. I'll stick with W7 as long as possible. With luck I might squeeze another ten years out of it.
i like it too, but on this one its not starting most of time properly and keeps installing a critical update that disables the pc once the fill windows screen is up. if you go to safe and uninstall it it works but it keeps installing even though its marked not to. Ive read win 7 is badly broken with all the latest updates so this may be why he updates are getting out of hand for some older pcs
I've blocked automatic updates and only install 'important' updates and not the loads of unnecessary stuff.
Gave my W10 PC to the grand daughters.
not had any trouble with my win 8 pc on win 10 so far. Its just about there now I think; just checking the apps etc. dunno if it will work yet
its up and im typing. so far so good. I will leave it for tomorrow re testing out. Pleased its at least going
it did that I think during the setup. Seems ok so far. Just letting the in house security do its first sweep as it was downloading something new, not sure what tbh.. I will go down shortly and witch it off. Tomorrow I will see if tunes works. might have to be updated... thats one of its duties lol, but hoping it will stream better than it did on 7.
