Hi
Today's work started last night, installing UF series diodes in my 2 Quad 306 power amps.
These diodes are very good for audio purpose making standard diodes well worthwhile replacing.
there are differences in the forward voltage specification between the 4001 - 4004 at 1v vs 4005-4007
1.7v so to replace part for part the UF 4003 is recommended.
in the 306 there are 6 x 1N4003 diodes, D5,6,7,8,9,10 on each channel, if doing this on yours
you will need some solder wick to carefully remove the existing diodes. The 306 has to be the
easiest of Quad amps to work on so is a delight. However this work needs extra care as diodes
inserted and soldered in the wrong way will result in very damaged equipment. There are nice
labels underneath the board showing you where each goes, but no labels on the top board
so you need to very carefully match position from what is seen underneath to what is on top.
taking care with D7 in particular
so 24 diodes later, the improvement in audio quality is very easy to hear.
a nice lunch later.. hmm where else can these go
8 went into my DBX 150x , another 4 into my Pioneer CD player's separate analogue
power supply.
Cheers / Chris
