Yep, only one winding. No isolation between source and amp could be an issue in some systems though.
Hunter S Thompson
I'm Richard.
Coincidentally, I have just re-installed my Promitheus TVC (standard version), while I re-box my Stereo Coffee LDR pre, and add a remote control to it. There are differences to the sound, but I couldn't say which is better. The only problem with the TVC is that the attenuator switch clicks when turned. But only when music is playing! It has been suggested that is due to DC being present on the inputs, but I don't know if that's true. Maybe it's just the Chinese 24 way switches, but it would cost over £70 for an Elma switch just to find out! And all those wires!
ABD.
A cap would block the DC. Does it do it from all sources?
Hunter S Thompson
I'm Nick.
DC on the input to a TVC would cause problem with saturating the core. Its more likely you need a make before break switch.
Nick.
I'm Richard.
Now had the chance for a proper listen. This is very good indeed. I thought the Forte was good, but this is better in every respect..
Hunter S Thompson
Holy shite, the bass out of this is phenomenal!
Hunter S Thompson
Had this long enough to get a good handle on it I think, I reckon this is one of the biggest audio bargains out there. This is easily the best pre I've had in my system, a great result given a pair of these autoformers are only 200 dollars. Don't let the low price put you off, performance is stellar. All you need then is a box, selector switch, volume switch, rca's and some wire.
Only caveat - Nick tells me it needs a lowish output impedance from your sources to give of it's best. The inductance can be altered by restacking the lams though, so there is scope for tuning the sound to your system.
Hunter S Thompson
