I use "Novus Plastic Polish".
http://cgi.ebay.com/ebaymotors/ws/eB...7717&viewitem=
You can get it other places.
Good stuff, may take some work depending on the damage involved.
Den
Den
Pathos Classic One MKII, Marantz SA15 S2 Ltd, Usher CP6371, Clearaudio Emotion, CMB, Carbon Satisfy arm, Vista Audio Phono 1 MKII ACLE, Dyna 10x5, AT OC9ML/II, Ortofon X5MC, All WyWires.
I'm Greg.
Duraglit polish wadding is a chemical treatment only. Not being abrasive it is unlikely to remove scratches from plastic. Brasso I would expect to be a bit course and leave a 'haze' although it might well work on a watch glass because of the glasses closeness to the face. It would be good to remove deaper scratches on an area later treated with a finer polish. Some people have had good results with toothpaste and the ultimate is considered to be Jewellers Rouge which I think is about the finest polish you can get.
The bottom line is, whatever the product, only superficial marks and scratches are likely to be successfully removed.
I'm Nobody.
Greygate is the best for superficail marks
http://cgi.ebay.co.uk/Greygate-Plast...918193001r2998
I just found the link on the polishing acrylic.May be useful .If German language is tabu,G translator can be used.
Copy/paste procedure
Speakers: WLM Diva Monitor
CD: Marantz SA8003
Tuner: Sansui TU-9900,TU-919...
Amplifier: Almarro A318B,Sansui AU-X1111 MOS VINTAGE,Sansui AU-11000A,...
Receiver: Sansui G-22000,Sansui G-7000,Sony STR-V7...
Another vote for the Novus products.
They are recommended by Stillpoints in the States and some bottles were supplied with my Stillpoints equipment rack for polishing the acrylic shelves.
For deep scratches, use the #3 Heavy Scratch Remover first and then apply the #2 polisher and finish with the #1 spray which is also a very effective polish and anti-static cleaner.
Steve.
My System:- dCS Vivaldi Transport + dCS Vivaldi Apex DAC + dCS Vivaldi Master Word Clock + dCS Vivaldi Upsampler Plus, Aurender N20 Music Server/Streamer, TW Raven One tt/Graham Phantom II/Transfiguration Orpheus L & Audio Technica ART20 mc's, Whest Titan Pro, D'Agostino Momentum HD pre/S250 MxV power amp, TAD CR-1 MKII loudspeakers, REL Gibraltar G2 subs, Coherent Systems BD Mains, interconnects & speaker cables, Sablon Audo EVO USB cable, Tellurium Q Ultra Silver power cords, Ziro Disclosure & Vertex Roraima Hi-Rez power cords + Furutech FI connectors, Stillpoints ESS racks/component stands, Vertex Aletheia PSU2 balanced power supply, Coherent Systems RTZ3 ground box + CR/BD cables, Acoustica Applicata DaaD room treatment, Mutec Ref10 SE-120.
Hi Steve,
How's your new phono stage then, matey? I haven't seen the review yet in S.O.G......
I had forgotten about this thread.
In the end I decided not to do anything, as I did not know what material the lid was made from. I could make it worse than it is.
Regards D S D L
Regards Neil
Steve.
Dear daftee,
Aha...thanks - off for a read now!
