AC POWER
AMPS
SPEAKERS
Wharfedale Evo 4.4
DAC
TURNTABLE
PHONOSTAGE
DIGITAL
MUSIC PLAYBACK
Ipad Roon Remote.
SPEAKER CABLES
INTERCONNECTS
How's the new arm getting on Gary?
Its a major step change from the Tecnoarm Grant, just....better.
Taking the deck into Jonny tommorow to give it a pro level fettle at Loud n Clear in Glasgow (his Saturday gig) and the deck will be.....
....ALMOST done.
AC POWER
AMPS
SPEAKERS
Wharfedale Evo 4.4
DAC
TURNTABLE
PHONOSTAGE
DIGITAL
MUSIC PLAYBACK
Ipad Roon Remote.
SPEAKER CABLES
INTERCONNECTS
Great stuff...
I'm Oliver.
Your deck looks gorgeous , I've got the SE in silver with a black arm (OL Encounter 3C) and after seeing yours I wanna black one too ..............
AC POWER
AMPS
SPEAKERS
Wharfedale Evo 4.4
DAC
TURNTABLE
PHONOSTAGE
DIGITAL
MUSIC PLAYBACK
Ipad Roon Remote.
SPEAKER CABLES
INTERCONNECTS
Speaking of black...the deck's now lost the bling and had a few other tweaks.
Much happier with both looks and sound now.
meet the Bat-Table.
Had an Orbe platter before when I had the Technoarm but the deck sounded a bit dead and shut in on some albums, and the Gyro platter gave a bit of extra sparkle which gave those albums a sense of life about them and I preferred the sound.
So sold the Orbe platter and kept the Gyro one.
With the SME V in play the sound of the deck changed dramatically over the Technoarm I had in before. So had a rethink about the platter....
Can now hear the improvement the Orbe platter brings, particularly in the bass which with the V is "rifle bolt" tight and goes really deep. Really deep.
Had J7 set the deck up for me too, so everythings set up as it should be.
Sounds great, really really happy.
Arm rewire in the future, POSSIBLY a cart upgrade if funds are there and I'll call vinyl done.
With the Orbe Platter kit, you get a pack of "Densodamp", which is the anti resonance compound to be stuck under the decks chassis to eliminate ringing.
Think ultra sticky blutak.
As my deck already had the compound fitted I took the opportunity to use it to apply other tweaks elsewhere.
I stripped the decks motor (really easy) and applied it to the inside of the motors housing and base, which is in two parts, aluminum tube and heavy solid base.
Damped the inside of the tube and the interface where the two parts meet to make the motor housing noticeably heavier and completely dead.
I also lined the clamp with a layer of the damping compound which again, made it completely inert vibration wise.
My thinking was it couldn't hurt and as the theory was sound I thought it might even be a good tweak?
The platter was fitted around a week so was familiar with the improved sound I had over the Gyro platter, so sat down to listen once the damping compound was applied.
Another boost in sound quality, greater sense of space and physicality of instruments in space.
Overall impression was of more control, but a more free-flowing higher resolution sound which motored along nicely, timing and interplay between the band being noticeably more obvious.
Soundstage was already beyond and behind the speakers, but the damping brought more 3D to the table and a greater sense of the room acoustic of the recording.
Listening to Allman Brothers at Filmmore was a real hairs on the back of the neck type of listen, loved it.
Just sounded...live and in the room.
Not hifi, but guys in a band in a room playing off each other...boogied like a bugger.
Happy days, decks almost done now but the important thing is its a big step up from the Gyro platter even with the SME in play.
Reckon I'm hearing more of what the arm is capable of now.
AC POWER
AMPS
SPEAKERS
Wharfedale Evo 4.4
DAC
TURNTABLE
PHONOSTAGE
DIGITAL
MUSIC PLAYBACK
Ipad Roon Remote.
SPEAKER CABLES
INTERCONNECTS
Looks very smart Gaz. .. bar the hairy stump
My best feature!
AC POWER
AMPS
SPEAKERS
Wharfedale Evo 4.4
DAC
TURNTABLE
PHONOSTAGE
DIGITAL
MUSIC PLAYBACK
Ipad Roon Remote.
SPEAKER CABLES
INTERCONNECTS
Nice one Gaz
