AC POWER
AMPS
SPEAKERS
Wharfedale Evo 4.4
DAC
TURNTABLE
PHONOSTAGE
DIGITAL
MUSIC PLAYBACK
Ipad Roon Remote.
SPEAKER CABLES
INTERCONNECTS
Spot on Marco.
A lot of utter rot is talked on forums about the standard wiring. The only thing it usually lacks is decent phono plugs but that's an easy fix for those impatient for a little more bling or better quality plugs. That aside, the wiring is purpose designed for the job, lowish capacitance, well screened and importantly, thin, light and flexible which is a MUST for not upsetting the Gyro's balance on its bouncy suspension. I make and sell a lot of cables and whilst my whole system is decked out with RFC Mercury and Pluto cabling, the only part that isn't is the cabling from my Gyro's SME arm. All I've done is to add better plugs. You simply wont achieve any sonic upgrades which can be attributable to cabling here. If you could, I would have done it years ago (and I have tried various options).
Cracking combo, the Gyro coupled with just about any of SME's tonearms and all British manufacture!
I'm Andr'e.
End of the day Gaz, do not worry what it sounds like, it looks good that is all that matters in this hobby innit?
AC POWER
AMPS
SPEAKERS
Wharfedale Evo 4.4
DAC
TURNTABLE
PHONOSTAGE
DIGITAL
MUSIC PLAYBACK
Ipad Roon Remote.
SPEAKER CABLES
INTERCONNECTS
AC POWER
AMPS
SPEAKERS
Wharfedale Evo 4.4
DAC
TURNTABLE
PHONOSTAGE
DIGITAL
MUSIC PLAYBACK
Ipad Roon Remote.
SPEAKER CABLES
INTERCONNECTS
I'm Andr'e.
o go on
Now now behave.
I'm Andr'e.
Sup grant you dont wanna hear the truth about audio enthusiasts?
I'm Deleted.
There does seem to be a fashion for arm cables that are just re-terminated interconnects; often this means they are both rather thick and rather too stiff - neither are desirable traits for suspended turntables as the cable will effectively bypass the suspension and possibly make it very difficult (if not impossible) to set up properly.
Account Deleted
AC POWER
AMPS
SPEAKERS
Wharfedale Evo 4.4
DAC
TURNTABLE
PHONOSTAGE
DIGITAL
MUSIC PLAYBACK
Ipad Roon Remote.
SPEAKER CABLES
INTERCONNECTS
