Still kicking back and enjoying the tchoons
Just as enjoyable as ever, but now cleaner, tidier and with new speaks and my old CDP installed
I think this'll do me nicely
Low Rent?
I would not call it that mike its higher end of the scale then that.
Kendal II's eh? What are they like in comparison to the conway's? I have the Durham MK1 Lovely little things they are must give them a run.
HMM QUAD.......LOVELY MY SON RUN MY 3 Series last week the magic is still their something i will NEVER let go thats a fact. I also have a 405 MK1 with MK2 Boards sounding excellent aswell classic power amps for sure. Have you got the Ken Kessler "Quad The Closest approach book its a fabulous read one to keep a look out for.
Bi Amplification
Quad 33 with current Mod for CD
2 Quad 303 Bi Amped
Turntable
CD Transport & DAC & PSU
Loudspeakers
Tannoy 615 MK2
Cassette
Goodmans GSW 435
Very tidy & nice turntable but wasn't keen on the phono stage in the 34.
Hiya Dan,
The Kendals are a touch clearer than the Conways but with a bit less bass; probably a bit better suited to my small room than the Conways tbh.
My 405 has the 405-2 boards fitted and I must admit it has really surprised me.
By low rent I meant cost as opposed to SQ. Other than the TT and the cart none of the other components worried £100
Bi Amplification
2 Quad 303 Bi Amped
Turntable
Loudspeakers
Tannoy 615 MK2
Cassette
Goodmans GSW 435
Well done you for costs
The 34 can have its op-amps looked at and there's a reliability check necessary on the supply caps too, which can leak all over the main board. If you haven't already, do please look at the Dada website as their update kits are not expensive and do really update without losing touch, if you see what I mean. I believe an op-amp change may be all that's needed...
I'm Shane.
That is a nice looking system, Mike.
Those Talk 3 cables have a good reputation.
S.
Thanks Dave,
The PSU caps 'look' to be in good order and there are no audible signs otherwise. On the subject of to upgrade or not, I think I fall into the camp of leave as is, as the SQ is perfectly respectable and I would prefer to own an original spec classic as far as possible.
I am, however, certainly thinking of changing input sensitivity as it can be a pain in practical use. Just not too sure how easy this is to do properly.
