Hi all,
Is there any reason why something like this....
http://www.mastershelf.co.uk/shopexd.asp?id=550
Would work any less well than one of the expensive purpose built turntable wall shelves?
Thanks,
Phil
Hi all,
Thanks,
Phil
Doesn't look anywhere near strong enough. You need something like this http://www.audioaffair.co.uk/pro-jec...FSTItAod5_AJTQ
Regards Neil
weight capacity of 30 kilos, who has a deck that heavy?
Lots of folk probably...otherwise I don't see why it would not be fine.
I'm Richard.
Leverage on the fixings, and possible resonance issues due to the cantilever design.
ABD.
I've not seen a TT wall shelf that was not a cantilever design. What other way to do it? And if the fixings are genuinally rated for 30 kilo, which it claims, how can that matter?
It may look good, but I wouldn't use it. It's only as strong as its wall fixings. Go for something with a bit of triangulation and multiple wall fixings to spread the load.
ive got a few floating shelves and they are strong but that comes out a fair bit. must put incredible stresses on the wall and the part of the shelf in the groove. see no reason why it wouldnt work as the tt wont be anywhere nere its claimed limits. one previso is that you can get it level. due to design a mil error at wall means quite a bit off plumb at outside so if your wall is perfectly level the! ok.
I've ordered one of these in maple (with matching isolation platform), which I'm going to use to house an Audio Grail-modded Garrard 301 or Thorens TD124, keeping the Techy on my Mana racks... Should be fun!
http://www.hifiracks.co.uk/hifi-racks/7/podium-platform
Lol... Not bought yet, but imminent! First stage is to provide somewhere to put it
Floor space is nil (for any more racks), so a wall shelf was the only way
