Well isn't that the point of Class A - it's simpler.. :-)
Hunter S Thompson
Don't leave it turned on! This is my advice for ALL equipment BTW but is especially important for units that get hot as the Kraken does. I was Chief Engineer with Alchemist BTW but not the designer of this model which was designed by Glen Gayle (as were most of the range). It's only class A up to approx 4 Watts.
I guess it's looks are a Marmite thing.... many (most?) owners bought them and love them because of the looks!. I still get a steady stream of these in for repair and/or rebuild and upgrades.
Can't disagree, but then from the stuff I've heard, power supply is everything when it comes to SQ.
For SS stuff, the Pass designs I've heard sound great. No feedback..
Hunter S Thompson
It's very important yes but is hugely over rated by audiophiles in general.... as with many other aspects of good sound! People read things in magazines or forums which are often simply wrong in the first place (or right only under specific circumstances) and then a process of "Chinese whispers" and expectation bias can sometimes lead to certain ideas becoming "accepted truth" even though they are 100% incorrect.... In the case of power supplies the important thing is that the circuitry being powered can have good or bad PSRR (power supply rejection ratio). With exceptional PSRR just about any old power supply will do fine and improving it will result in minimal SQ improvement.
With very poor or non existent PSRR, common in VERY simple circuitry, then the power supply itself is indeed hugely responsible for the SQ obtained.... but no more so than the design of the amplifier circuitry itself! It is also often not appreciated that the internal grounding regime used is every bit as important as the power supply itself and has exactly the same effects as the power supply itself....
Well I'm mostly talking about valve designs, but I'm talking from what I've actually heard, not just read. Yes agree grounding is very important too.
Hunter S Thompson
I can assure my knowledge, gained over decades as a professional, goes much further than just having read something somewhere!!
Much of what is said about hifi, technically, is simply wrong and has it's roots in marketing combined with "a little bit of knowledge is a dangerous thing"....
I'm Shane.
I couldn't give a shit if the Kraken is class A (Or AB). This is indeed a nice sounding amp in its own right.
S.
Yep agree, it's a good amp.
Hunter S Thompson
Heard yours at NEBO and liked it
