I'm Doug.
The Planet 2000 is the CD player. I thought a Planar was a turntable; or at least I remember my first Rega turntable being called a Planar 3. So I'm slightly confused here. Are you asking if the CD player is like a turntable in terms of sound quality? Or did Rega once have a turntable called the Planet, and I'm just unaware of it?
not sure which way he was meaning but yes, Rega did make a TT in the early 70's called the planet.
I'm Doug.
I'm Doug.
One small change in the system: I replaced the Rega DAC with a Muse HIFI DIR9001 + TDA1543x4 DAC. It's a NOS DAC that cost about 35 GBP or about 50 USD. I'm sure it's not the best implementation of NOS that's available, but I wanted to see if I liked the NOS sound. Turns out that I do, and I'll be looking for an NOS DAC sometime in the future.
I'd post a picture of it, but it's a tiny box, so it's lost somewhere in my cable mess You can see a picture of it on Ebay if you look.
The DAC does have drawbacks -- it's not always great sounding, but it's a lot better sounding than its price would indicate.
"...one door shuts and then another closes"
- Ian Dury
I'm Shaun.
Wow... would love to hear those loudspeakers on the end of Croft pre/power amplification.
I'm Doug.
I'm Steven.
I'm surprised the Luxman is powerful enough for the Harbeth. I lived with Harbeth and similar powered Class A valve amp for about 9 months, but on critical deep bass it just could not control the Radial 2 drivers. That said, for 95% of listening it was fine, just fell over at the low end.
http://www.harbeth.co.uk/usergroup/s...x-with-C7-ES-3
Wilson, Luxman, Innuos, Holo May, Puritan, Garrard
I'm Doug.
Was it the C7ES speakers you had, or something larger? I see you have SHL5 speakers in your signature.
I used tube amps for years, and there was almost _no_ low end -- so when I moved to the Luxman, it seemed to me as if there was excessive low end
I usually listen between 1-3 watts (or so I've been told by some serious stereo guys), so the Luxman has more than enough power for me. I think it's a great amp for people who like tubes, are tired of fussing with tubes, and are willing to compromise a little on the sound. Right now I'm running an NOS dac for digital and a tubed phono preamp for vinyl, so it all sounds pretty good to me.
- Ian Dury
