Can't cut and paste as it was a phone conversation largely over my head but essentially the voltage (or was it current?) is controlled by FETs leaving the 6SN7s operating always in their sweet spot so it's technically a hybrid. Vanishingly low noise and measurable distortion, and multiple power supplies for all the various stages (four I think though may be more) to keep noise and distortion down. Made to drive anything (very high - or was it very low?! - output impedance). Very much in the Radford tradition and designed exactly for the amount of gain the STA100 needs. Actually I think the gain was variable by jumper thanks to the FET stage.
Re-reading that just shows my ignorance but Will is a veritable genius and I trust what he tells me.
I'm Gone.
I have used many Pre/Power combinations over the years and I think my current set up of Art Audio VPL pre and triode mode AA Quintet is the best I've owned. I have also used the VPL to drive everything frob Quad 11s to Yamaha power amps and i has always performed. Well worth a listen.
I used a Conrad Johnson PV10 pre for a while and thought is was excellent... maybe something further up the Conrad line might suit... just a thought
Bev
Try and listen to a Puresound L300 if you can cope with the rather large dimensions. There are a couple for sale on different forums for around £2,500 which is a bargain considering the performance on offer. Also worth considering Shindo preamps if you can find any for sale
You say you want a valve pre-amp. There are superb alternatives. Have you considered Music First products? They have advantages, no valves for a start, so no tube rolling and biasing to be involved with. No power lead to get in the way or power supply hum fields near sensitive low level signals and there's the sound quality of course. TVC pre-amps just have something you just don't get elsewhere. Check the reviews. MF products have been described on more than one occasion as 'the best preamplifier in the world'.
Here's just one review:
http://www.6moons.com/audioreviews/m...t/passive.html
I've got a tvc and have to say its a revelation
Enjoyed my MFA MkII but whether it works well or not is incredibly source-dependent ... mine worked incredibly well with my AN tube dac and with the Longdog MM tube phono stage, but sounded flat with the Aurorasound Vida. It's not a panacea, worth borrowing one before buying one.
