The signal will degrade over distance but as long as you use low loss 75ohm impedance cable (like RG59 cable or the better RG6 cable) in a single run with no kinks or tight radius bends you should be fine. At the SPDIF frequency I would think there wont be much loss at all anyway.
Edit: one benefit if possible would be to fit the correct BNC sockets and plugs to the cable and equipment, this would terminate the cables correctly and minimise signal loss further.
