Made by Canadian high-end loudspeaker manufacturer, Verity Audio, the monitor sections of these are noted for their accuracy and musicality, as used in many recording studios Sateside and Canada. Rare and highly desirable in the UK. This pair was imported direct from the manufacturer by a high end Spanish hifi power supply specialist who intended using them to demonstrate their products but in fact ended up residing in their original packaging!
This beautiful and compact floorstander is comprised of two separate enclosures for the drivers, and can be positioned with the low frequency driver facing toward either the front or back. This results in a very flexible speaker that excels in both small and larger rooms, presenting a huge soundstage in a variety of room placements. Sound from the Rienzis consistently “expanded beyond room boundaries.”
35Hz-25KHz (conservative as in room response drops lower);
Easy amplifier load (benign impedance load)
87dB/1w/1m. Tube amps from 30wpc will drive these with ease. A good class A SE amp of 15wpc upwards will also drive these adequately.
Beautiful timber.
22cm by 29 deep by 100cm tall, weight approx 45Kg per speaker set (ie one side); 2-box system comprising monitor and separate bass unit.
Carbon composite (paper pulp/carbon) long throw woofer with dynamic damping system for low distortion at high volumes.
Bespoke mid range unit running virtually full frequency; self damped, ultra smooth with amazing transient response.
These, with the correct positioning can generate cathedral-like imaging!
Amazing, high quality loudspeakers.
RRP = £8,500 approx.
These are 2 1/2 years old and spend 18 months of that time packaged in their original packaging, unused. Since then, they have been demo units only so are barely run-in!!!
Complete with all original packaging, paperwork, high quality link wiring, spikes, damped separating plinths and owner's manual.
Immaculate condition, rare and desirable. Bargain at £3,900
PM me for more details f interested or contact me using my website contact page: http://www.referencefidelitycomponents.co.uk/contact/
