Hi Hamish,
As one very atisfied customer of this service I can thoroughly recommend it - good prices and good turnround but keep him in check regarding return postage service (nothing to get concerned about but might raise a smile on Marco's face ).
I was so impressed I'm planning to send some more - no better recommendation!!
Cheers,
DaveK.
My System:
Wot I use:
http://www.audiodestination.co.uk/in...oducts_id=1197
Dude, your records will be revitalised beyond belief!
Hi Hamish,
I might be interested but it would depend on the costs of shipping it between us - wouldn' need to be done all that often perhaps, depending on how often we buy shitty records from eBay and charity shops .
How heavy and fragile are these things - any idea?
Cheers,
CORRECTION. Just seen the price on Marco's link - bit out of my price league I'm afraid - sorry!
DaveK.
My System:
they arnt cheap are they?!?!
Nope. The Okki-Nokki will clean records just as well, but the VPI is better built, more powerful, quieter and a bit more refined in use
Dave & Hamish,
If you guys were going to go 'halfers' on one, the Okki-Nokki (much cheaper) is more than good enough for the job.
i aint botherd about quiet and refined... i just want less clicking and popping!
cheers for the pointers
Hi Greg, I've heard encouraging reports of the Mappleshade - yes it does look like a cheap steam cleaner. But I've no direct experience of it. What do I use? Loricraft PRC3. I could do a review, you're getting me thinking, they've got other tweaks that look interesting, here's another: http://www.mapleshaderecords.com/aud...ountsystem.php
BTW, let me know you latest bearing thoughts (same old email address).
DaveK.
My System:
I'm Greg.
Yes exactly, the Okki Nokki is a third world clone of the VPI produced by an Indian company called 'Cadence'. It doesn't look as good but it is equally as functional. It might be noisier but that is immaterial in my view. The noise is not worth considering when it's the cleaning that is your objective and in anycase, the vacuum is only on for three revolutions of the disc per side which is well less than 30 seconds. It doesn't seem to be an issue to me. All we are about here, after all is good cleaning!
