Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 51
Thread: Record cleaning devices - cheap = case economy?
  1. #21
    Doesnt seem to have made all that much of a leap forward in time and in many cases noise just in price...Not so sure the ultra sonic approach is a safe one for vinyl over and above a single clean imo.
    I think i will persevere with my moth. seems to work well still and takes less time and is way cheaper. be nice to see his results though when you get them Hugo
    I'm Phil.
    Thanks again, chaps.
  3. #23
    I'm Phil.
    I had an album I could afford to ruin with experimentation, so tried a suggestion from a contributor here, i.e. the (very) cheap and (very) cheerful option of warm water, washing up liquid, microfiber cloth and a rinse.
    I'm staggered at the results from such a simple act...I turned something that would have play-graded as 'good' (at the absolute best) to just about 'near mint'...a real result, as the item I was sacrificing had been a hugely disappointing £15 purchase from a record fair.
    Definitely buying a machine.
  4. #24
    I'm Charlie.
    Anyone with a serious vinyl set up should invest in a proper vacuum RCM. Whilst the high end Loricraft, Keith Minks and Audiodesk might be better at cleaning than a Moth, Okki Nokki, VPI, the difference is pretty marginal. If you don't vacuum the dirty liquid off, it will dry and deposit some (but not all) of the gunk back into the grooves.
  5. #25
    Im always amazed at the improvement i! even a brand new vinyl when its been cleaned on my moth..imo it was one of my best ever buys.
    I'm scott.
    Quote Originally Posted by topoxforddoc View Post
    Agree RCM 100% essential component if you buy Vinyl use a both a Audiodesk & Loricraft
    if you can,t afford £1000-£2000 to clean your records
    how about one for £200
    http://theartofsound.net/forum/showt...=record+doctor
  7. #27
    Box13 Guest
    Quote Originally Posted by Phil Lawton View Post
    Just mulling over the purchase of a vinyl cleaning machine.
    I've seen the range of machines and have to ask if buying one of the cheaper ones (typically £50-70) would prove to be a false economy. Should I simply bite the bullet and get a VPI machine?
    No.
    Save your money.
    A good cleaner for your computer screen will serve with a freshly laundered handkerchief.
    This is of course my personal opinion and I am not decrying anyone who likes to spend on their chief interest.
  8. #28
    I'm Nathan.
    I made my own for very little money. I bought the motor recommended on PFM for £12.95. I bought some 22mm overflow pipe and elbows from screw fix. I used these on the vacuum tube
    http://www.ebay.co.uk/itm/Moth-Recor...item35d0c9e51d
    The results are brilliant! Much better than my knosti disco antistat, in fact I sold that after which paid for everything!
    Take a look here.
    http://www.pinkfishmedia.net/forum/s...d.php?t=161218
  9. #29
    Box13 Guest
    Quote Originally Posted by nuff View Post
    Take a look here.
    Very clever.
  10. #30
    Box13 Guest
    Take a look here.
    Very clever.
