Hello all
I have taken a brave pill and decided 2 have a go at referbing the R2R machine
Have dismantled and cleaned all the front brushed alloy panels ,
I washed them in a washing up bowl of mild detergent , The muck that came off turned the water 2 a mild gravy colour
and when wiping dry the panels this is what was still on them
I assume the original owner was a smoker , God imagine what smokers lungs look like
Here are a few photos of the machine naked
Both VU meter bulbs were blown so I needed 2 find replacments ,
Ebay Germany 2 the rescue
http://www.ebay.co.uk/itm/2217563865...%3AMEBIDX%3AIT
When the bulbs arrived it was time 2 fit them , some head scratching later after getting access 2 the two VU meters I could not see how I could fit the bulbs ? The VU meters were soldered 2 the PCB , They did not have removable bulb holders and I could not see how they came apart , Had a look on the web ,no help , I was just about 2 give up when I noticed a slightly different colour strip running across the meter front cover and I could feel a very slight ridge , It turned out the VU meters were held together with sellotape , after picking at it I managed 2 remove it and get access 2 the bulbs
These are the two blown festoon type bulbs
and the replacements
Now fitted and working
I also have a bottle of capstan oil , replacement counter belt and a new pinch roller , again ebay Germany
http://www.ebay.co.uk/itm/1313265137...%3AMEBIDX%3AIT
The pinch roller is a work of art very good quality
Next job is 2 lubricate the capstans HELP , any ideas how this is done
Then clean the tape heads , Having read up it would seen these heads are glass , is it OK 2 use Isopropanol on glass heads ?
One other item the needs attention id the tape counter its stiff and gritty and reluctant 2 return 2 zero , any advice on cleaning and lubing ( if it needs lube ? ) or cleaning and drying ?
I will update this thread with progress / lack of progress as and when it gets done
Cheers for now
__
