Results 1 to 10 of 18
Thread: Proper anti skate reading
    I'm peter.
    Default Proper anti skate reading
    Hi everybody just wondering if anybody can explain which reading I should use for anti skate a bit confusing ImageUploadedByTapatalk1433259276.121445.jpg cheers.
    HEGEL H100 integrated amp
    REGA rp6/exact cart
    REGA Apollo r CD
    NEAT ELITE SE loudspeakers
    BERESFORD bushmaster mk2 dac
    Powered by a DEBEN tracer battery
    Mc5000 klotz ms audio cables(cheers Brian).
    REGA couple 2 ics
    JEZ ARKLESS phono stage
    RUSS ANDREWS powermax mains cables
    ISOTEK POLARIS mains block
    ATLAS Speaker cables
    CREEK OBH21 SE head amp
    BRIANS silver hybrid ics
    What does your cartridge track at, Peter?
    I'm peter.
    Hi Marco 1.8 gramme (2m red).
    Quote Originally Posted by clarkey555 View Post
    The numbers on the anti-skating (bias) control correspond to the numbers on the the VTF (vertical tracking force), or playing weight control (where the numbers are the playing weight in grams).
    So, for example, if you have set the playing weight to, say 2 gram, the bias control should also be set to '2'. In practice I find that for most arms the bias set in this way tends to be too high. Something like 50 - 80% of the playing weight is better; however to set the bias properly you will need to use an appropriate test record.
    I'd go with 1.5 on the anti-skate then, mate. It's a 'suck it and see' thing, though. Like Barry says, the most accurate way is to use a test record.
    However, 1.5 shouldn't be far off!
    I'm peter.
    Hi lads I know roughly what to set the anti skate to its the dial I cannot understand there is an inner reading and an outer reading on the jvc re the photo.
    Depends how old the TT is, but it may be that one set of markings is for elliptical styli and the other for conical.
    Yeah, that is slightly confusing... One for Paul Stewart to answer. If it were me, I'd be setting the dial midway between the '1' and '2' position, shown in your picture, right in the gap between the two bold black horizontal lines.
    I'm jamie.
    have a look over at vinylengine you may be able to download the original owners manual.
    start here http://www.vinylengine.com/turntable...ny&changer=any
    My System
    John Wood KT88 Amp.
    Paradise Phono Stage
    Sony TTS-8000 Turntable.
    PMAT-1010 MK6 Tonearm.
    Ortofon Cadenza Bronze
    Sony X555ES Cd Player
    Yamaha NS1000m Speakers
    I'm peter.
    Cheers for advice guys going to go with Marcos suggestion and use the bold black reading. Ps Geoff yep that sounds about right thing is I don't know conical/epilectal reading and vinyl engine doesn't recognise my password so no joy there. Having used Marcos suggestion I am pretty happy for now sweet as just a bloody perfectionist that's all. Appreciated
