Results 1 to 10 of 12
Thread: turntable isolation
    I'm jamie.
    Default turntable isolation
    thoughts on this please peeps,
    im currently using these http://www.ebay.co.uk/itm/3309876457...%3AMEBIDX%3AIT
    sandwiched between 2 boards,my turntable sits on the top board. is this ok? or can i do better?
    was looking at this. http://www.ebay.co.uk/itm/2519640375...%3AMEBIDX%3AIT
    turntable is 3 point suspended by the way in a rack.
    My System
    John Wood KT88 Amp.
    Paradise Phono Stage
    Sony TTS-8000 Turntable.
    PMAT-1010 MK6 Tonearm.
    Ortofon Cadenza Bronze
    Sony X555ES Cd Player
    Yamaha NS1000m Speakers
    I'm Yetkin.
    hi Jamie, Do you know the material for the ball at isocapfeet... İ could not find at the description
    And what is the total weight upper platform of existing sandwich with turntable together more or less. because with sorbothane not only upper load capacity say here 16 kg. is important. Sorbothane has also a lower load limit. Best works between upper and lower limits.
    Please go through this link
    http://www.sorbothane.com/engineering-design-guide.aspx
    I'm jamie.
    hi,
    thanks for your reply,my turntable weighs 8.2 kg,the board it sits on weighs approx 1 kg so roughly in the middle of the weight specs for the sorbothane cups.
    My System
    John Wood KT88 Amp.
    It's not costing a king's ransom so if it were me I would give it a go. It may be better, worse or do nothing - only one way to find out.
    Hi Jamie,
    I use four of these under a platform made from a laminated dense isolation material, it is very heavy and similar to slate in acoustic properties, but you could use a 3 inch maple wood shelf. I then stand my turntable on the shelf but the VPI Scout has its own ball bearing tipped isolation feet. It works very well Indeed.
    Have a look at some of the suggestions the Vibrated company have for building a platform with the sorbathane vibrapods.
    Good luck
    http://www.vibrapod.com
    I'm Anthony.
    The isofloat is very good at that price
    Our education is wrong, it takes no note of the subtleties of human nature, it places more importance on the memory of an individual than how memorable an individual is. Bernard Sumner 1995
    I'm jamie.
    thanks,i like the look of those
    cant find any info on building a platform though.
    My System
    John Wood KT88 Amp.
    I think they suggest to use two shelves with Vibrapods in-between.
    or you can use vibropod cones with them
    I'm jamie.
    seems im already on the right track then with my sorbothane ones and the sandwich.
    thers no info on line at all regarding this one http://www.ebay.co.uk/itm/2519640375...%3AMEBIDX%3AIT
    My System
    John Wood KT88 Amp.
