Results 1 to 10 of 13
Thread: Record cleaning machines - Audiodesk vs Loricraft/Keith Monks type
    montesquieu Guest
    Default Record cleaning machines - Audiodesk vs Loricraft/Keith Monks type
    A modest bonus in June salary is making the likelihood of upgrading my RCM a distinct possibility. The old Moth works well enough but it's too noisy to use when the wife is around, meaning I only get it out when she is away doing stuff (and even then a lot of the time I can't be bothered).
    I'm looking for something I can keep in the living room and possibly run while music is playing - the Loricraft models seem to allow that and I like the point vacuum approach.
    However the Audiodesk seems to get some good reviews - easy to use, and thorough, although consumables appear to be an expensive down-side ...I have something like 4,000 records altogether so cleaning them all would be a pricey task. (I'd probably never get round to it anyway but I would like to be in a position to clean as I go, any time I find a dirty one, get it sorted there and then).
    Anyone with direct experience of Audiodesk vs Loricraft type? I'm not far away from being able to pull the trigger on one or other.
    I'm jamie.
    When you upgrade would you sell the moth?
    My System
    John Wood KT88 Amp.
    Paradise Phono Stage
    Sony TTS-8000 Turntable.
    PMAT-1010 MK6 Tonearm.
    Ortofon Cadenza Bronze
    Sony X555ES Cd Player
    Yamaha NS1000m Speakers
    montesquieu Guest
    That's the plan. Another AoSer has first refusal.
    Well, a friend of mine says the Audiodesk is the dogs b**llocks, the best of your options.
    Quiet enough to use as you listen? I doubt any of them are.
    I'm Gone.
    As people know, I have an involvement with Loricraft, these days on a casual basis. All I will say is that I looked at ultrasonic cleaning 25 years ago. It works by cavitation and in every other use I could find, cavitation causes damage. This is piling energy into delicate vinyl with microscopic detail on it. Cavitation can destroy steel and hardened brass in ships propellers for instance. It has been proved that a good vacuum RCM, with the right fluid can clean a record over a thousand times with no damage.
    I'm Allen.
    Loricraft would be my choice , I have used one once and hopefully one day will own one , Until then its the Moth 4 me
    The advantage of the audiodesk seems to be that very little is required of you, you just stick the disc in and press a button. I do wonder if the air drying is as effective as vacuum suction drying, though. And as Paul says does the sonic action damage the record? I'd guess they would have tested this fairly extensively though.
    I don't really understand why folk complain about the noise these things make. Even on a Moth it is only a couple of minutes to clean a record. Is it really necessary to have music on every waking minute of every day? (no doubt someone will come straight back and say 'Yes!' )
    I'm Allen.
    NO
    It would keep me awake
    montesquieu Guest
    On the Moth type:
    • 4000 records is a lot to clean fully manually
    • Hassle factor - getting all the bits together
    • Noise - it's basically a vacuum cleaner in a box
    I want something I can use on the fly - I like both the nozzle ones and the idea of the Audiodesk (though I've never heard/seen one of those directly).
    I'm Don.
    I have owned both and I prefer the Loricraft. It is much quieter, although if you truly want quiet, the PR-6 is even quieter than my PR-4. I also feel that the records are cleaner. The Audiodesk can't be beat for certain types of dirtiness, but the Loricraft allows different types of cleaner and you can scrub away dirty, greasy fingerprints or go over certain areas again and again.
    I won't buy an ultrasonic again for another reason...a fellow on an American forum cleaned over fifty records in a row on his KL Audio ultrasonic and he had migraines for over a week and suffered other symptoms. You are exposed to high frequency noise, but can't hear it. A couple of records are probably fine but the gist of his story was to put the machine in the garage. He stopped listening to his Shindo system for over a week after that. You are supposed to listen to more not less.
    Although there is noise with the Loricraft, you could still listen to music with it running. I have several types of cleaning fluid but my favourite is the Art Du Son.
    Vertere SG-1 Turntable / Audio Note IO Gold MC
    Audio Note AN-S8L MC Transformer
    Audio Note Pallas I/C (SUT-Preamp)
    Audio Note M6 Phono Preamp
    Audio Note CDT 3/Audio Note 4.1X Balanced Signature DAC
    Audio Note Kassai Monoblocks
    Audio Note Sogon Interconnects
    Audio Note Pallas Interconnects
    Audio Note AN-Vx Interconnects
    Audio Note Sogon Speaker Cables
    Audio Note AN-E SPE HE speakers
    Audio Note ISIS Power Cables
    Loricraft PRC-4 Record Cleaning Machine
