Originally Posted by
Tripmaster
If you fancy having a go at veneering....... I'll be happy to provide some tips if required.
Richard
Hi Richard,
I'm looking for a couple of tips: -
What adhesive do you use to stick the veneer to the underlying wood? and,
How do you get a 45 degree chanfer on something so thin and fragile when you need to 'seemlessly' join 2 shhets at right angles
Mine is a very simple project: covering some shelves in my 'sideboard'/hi-fi unit that I added myself in oak veneered MDF but which don't match the other shelves.
Thanks for any advice.
Cheers,
DaveK.
My System:
