Results 11 to 20 of 27
Thread: Small RPi/IQAudio DAC+ Review
    I'm fabulous.
    Thumbs up
    I'm very pleased with my PI2 and IQAudio DAC+.... put it all together last night and did some quick listening and I was impressed.
    I opted for the RuneAudio solution - but just spent the last hour reconfiguring it to get the hardware volume control working. Now it was a huge surprise (and initial shock) to see that the volume control is now logarithmic in its use. So 99% is really loud and 70% quiet and 50% might as well be mute.
    Going to listen to some tunes tonight with a glass of Pinot Noir (or two)
    Glad you're having a good experience as well
    lossless > Raspberry PI-3b+ > allo Boss > Van Damme Purple interconnect >
    Myryad Z210 CD Player > Chord Chameleon Silver+ interconnect >
    into Magnum IA170 amplifier > Van Damme Blue 4mm cable > Mission 752 Freedom Floorstanders
    Headphones: Audio Technica ATH-AD700 Open-back
    There was a discussion about volume control in the rune audio forums "Volume control; Linear or logarithmic?" , see:
    http://www.runeaudio.com/forum/volum...hmic-t254.html
    Someone claimed to have found a best fit curve from data put into Excel, integer=rounddown(120*log(volume)+15). Gordon of IQaudio got involved.
    Chris
    Stuff
    1. Linux PC with onboard HDA SB/ALC892 24/192 optical S/PDIF and/or USB > TC-7520 (Gator + LM4562NA) > Quad 306 > AVI Neutron 3
    2. Rotel RCD 965BX > TC-7520 ( Gator + LM4562NA) > Hd595
    3. Rpi B+/HifiDigi B+ (with isolation transformer) Running "SqueezeOnArch" - https://github.com/SqueezeOnArch
    Nonsense
    1. Belkin Pure AV (white) phono, Belkin Pure AV (silver) USB, QEd 79-strand speaker cable.
    2. MG belden digital co-ax
    I'm Josie.
    Thanks Chris... that's cool but I simply don't understand that at the moment.. lol
    Could you explain that a little?
    Tannoyista.com
    Facebook
    I'm Josie.
    !!!FOOOOKIN' NORAH BATTY'S PAJAMAS!!!
    Just plugged it direct in to the amplifer.... Oh my!... Marco, you are a bloody star!!!! - I see what you mean now!
    Tannoyista.com
    Facebook
    I'm Rich.
    Well I spent the last day or so toying with mine and I can say with confidence that running the Pi through USB to an MF Vlink and then to my Rega DAC gives the best results by far. No messing with any settings or tweaking of volumes on the device required.
    As such I'll be offering my IQ DAC and case for sale here and putting the Pi in a case in its own. Fancy one of those wooden ones actually. I just can't get away with the sound of the IQ DAC... definitely not my cup of tea.
    Anyone interested in an IQ DAC and case is welcome e to PM me...
    One of these days... I'm going to cut you into little pieces.
    I'm Josie.
    Fair enough. lol
    I don't mind a bit of tweaking.
    You had best get it in Private Exhibitions then.
    Tannoyista.com
    Facebook
    I'm Gary.
    Quote Originally Posted by Krisbee View Post
    Ah the Rasberry Pi...plug and play computing for the Everyman.
    AC POWER
    AMPS
    SPEAKERS
    Wharfedale Evo 4.4
    DAC
    TURNTABLE
    PHONOSTAGE
    DIGITAL
    MUSIC PLAYBACK
    Ipad Roon Remote.
    SPEAKER CABLES
    INTERCONNECTS
    OK, did you read the discussion in that thread? My understanding is it was started by users who were controlling their sound volume via the widget on the web interface. They found dialling it down from 100 to 50 did not halve the perceived sound volume, but reduced it to very low levels. Hence the following discussion about the nature of the volume control ( linear or logarithmic ) and how the underlying software was working and the interaction with any in-built hardware volume control that might exist on their DACs.
    A fair comparison would be with controlling the volume on a HiFi amp which used a classic potentiometer. Turn the knob of your hifi volume control from maximum to halfway, and has the volume halved, or is it some other reduction in the volume that you hear?
    For audio applications, logarithmic rather than linear potentiometers are preferred, as the variation in loudness as you go from a min to a max setting is closer to the way the ear behaves in its response to loudness. This diagram summarises the two scales:
    The formula I quoted was someone's attempt to establish if the volume control dial on the web interface matched a linear or a logarithmic scale. The census seems to be be it was the latter.
    The discussion then revolved around how this volume control dial on the web interface was actually linked to the MPD (Music Player Daemon) internal volume control and not the volume control that can be done via the use of either the “alsamixer” or “amixer” command line programs. There is also the added complication of what, if any, type of volume control is built into the DAC hardware, and how this can/should be harnessed in software. This is where Gordon of Iqaudio came in.
    What can you take from this technical discussion? I think you have two viable options.
    1. Set DAC levels using alsamixer that suit your hifi setup and disable volume control via the web interface. Then control volume via your hifi controls.
    2. Set DAC levels using alsamixer that suit your hifi setup. Set volume control via the web interface to use “mixer_type” of “hardware”. Then you can either control volume via the web interface or via via your hifi controls.
    If you use option 2 above, then you can calibrate the volume control on the web interface yourself. Just connect to your RPI via SSH as root, start the “alasmixer” program at the command line and watch how the levels change in the “alsamixer” display as you vary the volume dial on the web interface.
    Chris
    Stuff
    Nonsense
    Quote Originally Posted by RichB View Post
    Maybe one of these might suit you : https://www.pi-supply.com/product/hi...ormer-version/
    Chris
    Stuff
    Nonsense
    I'm Rich.
