Main system: Sony TTS8000; AT1010; Audio Technica Art1; The Lentek; Cambridge 851n, Yamaha NS1000.
System 2 - SBT; Technics SH-X1000 DAC; Denon PMA-850
I'm Shane.
Rega Planet...Good choice!
S.
Looks great Geoff. Very envious of that Sony TT.
nice seat
The seat needs welding. I only have it there for sport as it collapses as soon as it's sat on!
The listening position looks great Geoff.
Me so horny- Impulse H6 Horny
I am on the look out for a nice big seat. My hip is killing me sitting on the couch lol...ment to say the gear aint half bad either....especially the Naks
The Nakamichi amps are superb Grant. A Nelson Pass design for Threshold, licensed by Nakamichi and £3k a piece in 1988. Top notch phono stage within with variable gain, loading and capacitance on external switches. I am reliably informed that Nakamichi used the 801's to voice the amps so they seem a superb match. They're fully serviced and re-capped too.
I owned these amps (CA7 and PA5mk2 to be precise). The PA7 will be great for the 801's (I know them as well in comparison with KEF 105 and 'Briks of the period prior to single-speaker dem rooms), but I think you'd be very surprised by a preamp upgrade one day. I was bowled flat by an ARC SP9 and SP14 in direct comparison (fine cachet but equalled in sonics by cheaper preamps by Croft for example and this was 1989 or so). Blame hifi dave for it - I didn't believe him either
What I discovered Dave was that in the size of the room that I now have the Nakamichi and 801 combination just works. I have tried various pre amps and phono stages but always come back to the CA7. I often think that other pre amps are more revealing and immediately impressive but if I keep listening I begin to appreciate that the CA7 reveals just as much but in a more subtle way.
