Yes..The op of the audiolab is 2.5..I have 2 attenuators..will try that. I love the detailed sound of the Emille......
Tim
Thanks paul,
Yes, if you follow the signal path [shown on last pick] you will see that there is just a grid resistor to ground[normal] and nothing else in the signal path to pin two on the valve base, which is the grid of the first gain stage!
Hope this helps.
A...
Nikola Tesla
www.tubedistinctions.co.uk
Matthew 5:10
Nikola Tesla
Matthew 5:10
Thanks Anthony, very helpful. I'm sure that Tim could try this mod or have someone do it for him locally and (hopefully) job done. RE rating, yes of course, it's not on the Hv side of the circuit. Cost = a few pounds Well spotted. Presumably a similar cap on the output stage of the CDP would work equally as well?
No worries,
Some source equipment, like CD players etc have directly coupled output stages, ie; they have no cap on the output to block and isolate the output, so if there is any significant level of DC offset coming out of the player's output, they can upset the front end of amplifiers with no input capacitors fitted.
Hope it fixes the issue.
A.
Nikola Tesla
Matthew 5:10
You would need a larger capacitor value, so more expense, at the CDP output as you would be driving into the impedance of the volume control on the Emille.
The impedance of the first grid is a lot higher so 100nF is OK there,
Good shout Anthony about possible DC offset
Alan
Nikola Tesla
Matthew 5:10
I'm Sam.
But the thing that people are forgetting is that the Audiolab worked absolutely fine with the Emile amp for a whole 20 minutes before starting to distort..
That would suggest the Audiolab was at fault (e.g. a sudden DC offset caused by a dry joint which kicks in after 20 minutes warm-up) and adding a cap on it's output (if it doesn't have one) wouldn't fix the fault it would only be a work around.
Need to check if it is indeed the Audiolab and to see if the fault always kicks in after 20 minutes from cold consistantly.
A very quick check of the Audiolab with a voltmeter on the output (when the fault is showing) will confirm or discount the Audiolab at fault.
