Heard Talk 3 with my RS3's when I had them.
It was the second best cable I'd heard with them, only bettered by TQ Black.
Even then the Talk 3 got very close.
Best of the rest, great cable...recommended 100%.
AC POWER
AMPS
SPEAKERS
Wharfedale Evo 4.4
DAC
TURNTABLE
PHONOSTAGE
DIGITAL
MUSIC PLAYBACK
Ipad Roon Remote.
SPEAKER CABLES
INTERCONNECTS
I'm Shane.
No, they're the previous incarnation. The room is quite small: 13' x 12', solid brick walls and concrete floor. I think the Rega drives them very well, but I don't listen to much rock or heavy-metal.
I tried them on the end of a Quad 606; it was better, but not by much. I think the R has more oompf than some would give it credit, or maybe the 11s don't need as much power as some say; or maybe I'm just deaf !
I'm Shane.
@ Martin, Thanks for that. As they say, ''trust your ears''.
Does the Brio-R fair well with VDH speaker cable?
I've also got ''The Snowline'' speaker cables as well. http://www.vandenhul.com/products/ca...e-halogen-free
S.
The Brio-r works well with any cable, why shouldn't it. If you already own the VDH, you can buy a Brio-r, confident that it will sound good.
I'm Shane.
Thanks for the reassurance, Dave
S.
I'm Shane.
Chaps,
The volume on my Rega Brio-R...
When turning down VERY low, one channel will disappear. While the other one can be heard.
Is this amp employing a rather cheap volume pot?
S.
